I’m running into a roadblock trying to automate the reopening of Intercom tickets based on Jira issue status changes, and I’m hoping for some guidance or creative solutions!
Here’s my ideal flow:
An Intercom ticket creates a Jira ticket in status “TODO.”
The Intercom ticket is set to CLOSED and marked with the state “backlog.”
When the Jira ticket’s status changes to DONE, the Jira for Tickets app adds a note back on the corresponding Intercom ticket.
I want the Intercom ticket to automatically reopen at this stage.
What I’ve tried:
Automation Trigger: “When teammate adds a note”
This SEEMS promising, but Jira’s integration writes the note as “FIN” (not classified as a teammate), so this rule doesn’t trigger as needed.
Automation Trigger: “Jira issue status is updated” (external event)
While this trigger detects the status change, it doesn’t allow me to execute my data connector (called “re-open ticket”) to reopen the ticket. It seems the automation does not permit calling data connectors when triggered this way.
What works:
My custom data connector to “re-open ticket” does successfully reopen tickets if triggered manually.
What options do I have?
Is there another trigger or workaround to act on notes/comments added specifically by Jira/FIN?
Can external events like “Jira issue status is updated” be used to trigger data connectors, or is this a limitation?
Are there alternative best practices for ensuring the Intercom ticket reopens automatically when the Jira issue is marked DONE, even if the event is not teammate-generated?
Additional Context
I’m using Jira for Tickets app (cloud), and have Intercom Workflows and data connectors available.
The main hurdle is that neither the “teammate note” nor the “external event” triggers fit my exact needs due to automation restrictions or user classification.
Any advice, workarounds, or triggers I might have missed?
Thanks in advance for any insights!
