I need to automatically close conversations with workflow | Community
  • November 28, 2023
  • 336 views
Lucía
Hi! We currently have a set of rules to close conversations automatically when we recieve messages such as spam and notifications. I am currently migrating those rules to the new workflows settings, but I can’t seem to find an action for it:
Is there another way to acomplish this?
Thank you!
Hey @Lucía 👋
The close action is not part of rules, but can be found under the main menu “Add action” when creating a Workflow.
In this case, you can use other actions within the rules, such as tag conversation, and then add the close action as the final step, or you can use Branches for this flow, as per the screenshots below 👇
Using rules
Using branch
I hope this helps!
Larissa Alberti
Hey @Lucía 👋
Using rules
Using branch
I hope this helps!
Lucía
  • 21 replies
  • November 29, 2023
Thank you so much, Larissa! I had been stuck with this all afternoon.
Have a great day!
