Resolution Bot won't get triggered while Custom Bot is set to live. How can I have them simultaneously running? | Community
Question
  • September 9, 2022
  • 36 views
It seems that when the custom bot is live the resolution bot does not trigger, so I'd like to know how to get it to work if the custom bot doesn't satisfy the user's questions?
  • September 12, 2022
Hey @tafari​ 👋 A good option here may be to set up your Custom bot to "Let Resolution Bot respond" 👇:
Screenshot 2022-09-12 at 17.10.08There is a helpful Article here which goes into more detail about how these two bots work together here. I hope this helps 😃.
