how can i make the massenger open beasd on plan and work houres
like
if the plan is pro and paid yearly
show the massenger 24 h
if the plan pluse and paid monthly
show the masenger beasd on sepecifice work houres
else show email form and respond like we will connect you in work houres
Workflow and conditions
Hey
Larissa from Intercom Support here. Thanks for reaching out!
You can create some workflows with the trigger "When a customer visits your website" and then apply the conditions to the audience. For example: plan is pro or plan is plus.
Then, on the Frequency and Scheduling section, you can select āany date, any timeā, āoffice hoursā or ācustom timesā.
For more information on this type of workflow, Iād suggest that you check this article.
I hope this helps!
Join the Intercom Community š
Login to the community
Log in with SSOor
