Hi, where do you hide the help center's language selection menu? | Community
LanguageControlMenu
Best answer by Graziela
You have to delete the supported languages on configure and style
Kevin Bendixen
Don't know if it's possible. If you delete one of the localizations, it might disappear, but that might not help you at all. Why would you want to hide it anyway?
  • April 14, 2021
Here's the answer from Intercom support: "The button for selecting languages can't be hidden, it will always appear when there is a second language added to the help center. I will raise this as a feature request to the team also." So hopefully it'll be available in the future.
  • November 12, 2024
It’s there even if there’s only one language to select from. The Intercom product team treats it as an expected behaviour.
Graziela
Innovator ✨
  • Innovator ✨
  • 45 replies
  • November 21, 2024
