install react-native for android error | Community
  • June 10, 2024
  • 8 replies
  • 566 views
hi guys, on "@intercom/intercom-react-native": "7.1.1", I can install but I got crash on android like this issue https://community.intercom.com/mobile-sdks-24/android-react-native-app-crash-when-call-intercom-present-7157
I just saw that we have new version 7.1.2, then I tried and got error. as below
ERROR:/Users/.../.gradle/caches/transforms-3/c8ba025c063d3a20a304d04e63c063d1/transformed/vectordrawable-1.2.0-runtime.jar: D8: java.lang.NullPointerException
ERROR:/Users/.../.gradle/caches/transforms-3/0425b92879a90be481c24e3266c7dff1/transformed/vectordrawable-animated-1.2.0-runtime.jar: D8: java.lang.NullPointerException
FAILURE: Build failed with an exception.
* What went wrong:
Execution failed for task ':app:mergeExtDexDebug'.
> Could not resolve all files for configuration ':app:debugRuntimeClasspath'.
   > Failed to transform vectordrawable-animated-1.2.0.aar (androidx.vectordrawable:vectordrawable-animated:1.2.0) to match attributes {artifactType=android-dex, asm-transformed-variant=NONE, dexing-enable-desugaring=true, dexing-enable-jacoco-instrumentation=false, dexing-is-debuggable=true, dexing-min-sdk=24, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
      > Execution failed for DexingNoClasspathTransform: /Users/.../.gradle/caches/transforms-3/0425b92879a90be481c24e3266c7dff1/transformed/vectordrawable-animated-1.2.0-runtime.jar.
         > Error while dexing.
   > Failed to transform vectordrawable-1.2.0.aar (androidx.vectordrawable:vectordrawable:1.2.0) to match attributes {artifactType=android-dex, asm-transformed-variant=NONE, dexing-enable-desugaring=true, dexing-enable-jacoco-instrumentation=false, dexing-is-debuggable=true, dexing-min-sdk=24, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
      > Execution failed for DexingNoClasspathTransform: /Users/.../.gradle/caches/transforms-3/c8ba025c063d3a20a304d04e63c063d1/transformed/vectordrawable-1.2.0-runtime.jar.
Best answer by bernice
Just an update on this issue - in the most recent release of the React Native SDK (7.1.3) we have removed vectordrawable library, which resolves this issue 🎉
You’ll find info on the latest React Native release here 📌
  • June 12, 2024
Also experiencing the same problem..
Hi Trinh Nguyen and Jack Sopher It’s Mat from the Support Engineering Team 😀
It looks like something that our engineers might want to investigate.
Please reach out to us via Messenger in your workspace so we can create a bug report for our Product Team.
  • June 14, 2024
hi @mateusz.leszkiewicz where I can find Message in my working space ?
  • June 14, 2024
Trinh Nguyen when you go into your Inbox (the icon on the upper left corner of the screen).
The Messenger icon will appear in the bottom-right corner of the screen.
bernice
  • Expert User ✨
  • June 19, 2024
The error you are encountering seems to be related to issues with the vectordrawable and vectordrawable-animated libraries in your Android project while using the Intercom React Native SDK. Here are some steps you can take to resolve this issue:
1. Update Dependencies
Ensure that all your dependencies are up to date. Sometimes, conflicts arise from mismatched versions of dependencies.
npm install @intercom/intercom-react-native@7.1.2
cd android
./gradlew clean
./gradlew build
2. Update gradle.properties
Ensure your gradle.properties file contains the following lines to use the latest versions of Android Gradle Plugin and Kotlin:
android.useAndroidX=true
android.enableJetifier=true
org.gradle.jvmargs=-Xmx4608m
3. Check build.gradle
In your android/build.gradle and android/app/build.gradle files, ensure you are using compatible versions of the build tools and dependencies:
android/build.gradle:
buildscript {
ext {
buildToolsVersion = "30.0.3"
minSdkVersion = 21
compileSdkVersion = 31
targetSdkVersion = 31
kotlinVersion = "1.5.10"
repositories {
google()
mavenCentral()
dependencies {
classpath("com.android.tools.build:gradle:4.2.2")
classpath("org.jetbrains.kotlin:kotlin-gradle-plugin:$kotlinVersion")
android/app/build.gradle:
android {
compileSdkVersion rootProject.ext.compileSdkVersion
defaultConfig {
applicationId "com.yourapp"
minSdkVersion rootProject.ext.minSdkVersion
targetSdkVersion rootProject.ext.targetSdkVersion
versionCode 1
versionName "1.0"
buildTypes {
release {
minifyEnabled false
proguardFiles getDefaultProguardFile('proguard-android-optimize.txt'), 'proguard-rules.pro'
compileOptions {
sourceCompatibility JavaVersion.VERSION_1_8
targetCompatibility JavaVersion.VERSION_1_8
kotlinOptions {
jvmTarget = '1.8'
4. Clean and Rebuild
Perform a clean and rebuild of your project:
cd android
./gradlew clean
./gradlew build
5. Invalidate Caches/Restart
If you are using Android Studio, you can try invalidating caches and restarting:
  • Go to File > Invalidate Caches / Restart
  • Click Invalidate and Restart
6. Use Compatible Versions
If the above steps do not resolve the issue, try using a previous stable version of the Intercom SDK that you know works, and gradually upgrade your dependencies to identify the conflict.
By following these steps, you should be able to resolve the issue related to the vectordrawable libraries and get your project running with the updated Intercom SDK. If the problem persists, consider reaching out to the Intercom support team or the community for more specific guidance.
Experts opinion
aykut.aydin
  • July 11, 2024
Thanks for the reply here @Celvin Pieterson!
@Trinh Nguyen @Jack Sopher, as my teammate Bernice mentioned, this should be resolved on the new version.
Please do let us know here if you are still experiencing the same issue on v7.1.3.
