Anyone using PowerDialer with Intercom? | Community
  • October 8, 2024
  • 117 views
Our team currently uses PowerDialer AI for sales outreach, and I've recently learned about its integration capabilities with Intercom. I'm interested in hearing from those who have experience with a Dialer + Intercom integration.
I'm particularly curious about the effectiveness of syncing call data, automating follow-ups, and managing customer interactions through Intercom when integrated with a Power Dialer. Any insights on potential challenges or tips for optimizing the workflow between these two platforms would be valuable.
If you've implemented this integration or have relevant experience, I would appreciate your thoughts and recommendations. Your input could significantly help in evaluating and potentially improving our current processes.
Hi @SuhanAshraf, It’s Mat from the Support Engineering Team 😀
I hope you will find user stories about PowerDialer usage. Can you tell me more about your use case?
Maybe I can suggest you some f Intercom native solution that will fit your needs.
