How To Delete A Conversation | Community
Just talked with Intercom staff through chat and got feedback that seems odd to me.
Feedback was that there is no way to delete / archive a conversation.   You can either delete a user (not what we want to do here) or use API to delete the conversation.
This seems like the most basic of functionality that is missing.  How are others getting around this?
Only thing we can think of now is to add a conversation data element called “Deleted” and set that every time we close something we want to delete.  But to close, we have 5 different required fields--so those all have to have a “Deleted” option in them.  Then every report needs to ignore those.   This seems like a lot of extra steps to workaround a basic function being missing.
Hey there @Paul Heering !
The agent that you spoke with is correct. You will need to use the “Delete a Conversation” call in the Unstable version of our REST API in order to delete a single conversation.
It sounds like you want to delete a conversation via your workspace, is that the case? If so, I just wrote up a Blog post here in the forum that discusses how to use Custom Actions with our Reusable Workflows trigger to delete a single conversation straight from the Help Desk. You can find that here!
  • March 27, 2024
  • 441 replies
  • March 31, 2024
