Inbound emails for specific brands - need urgent help | Community
  • February 20, 2026
  • 224 views
We have one workspace but multiple brands. I’ve been trying to get an answer on this question but the person helping me just stopped replying. And we need to urgently resolve this issue.
We want to use app script to forward emails because we have complex filtering requirements. The issue is that when we send it via app script, it goes to the default workspace instead of the brand that’s sending the email. Which also means we are replying back from the wrong email.
I tried using the workflow automation to fix this but it will only allow me to set a specific inbox, and while we have brand specific inboxes it doesn’t resolve the actual issue. I don’t see a way to set the brand using workflow automation.
An agent told me “If you need the per-brand forwarding address again: edit the brand address → change/disable receiving → choose “Set up forwarding” and the unique @intercom-mail.com for that brand will be shown again so you can copy it, then re‑verify.”
However, this does not show up in the UI. I have tried several times and I cannot find it anywhere. If we get an unique inbound address for each brand, that will fix the issue.
Best answer by Thomas Metcalf
Try creating a workflow ‘When customer sends their first message’
  1. Filter for a specific channel (Email)
  2. Use a Branch with the ‘Email to’ attribute with the ‘is’ condition
  3. Apply the email in the ‘is’ condition
  4. Use branching to route a a Team Inbox
At least the contacts will route to the correct team even if the Brand is set incorrectly
  • Innovator ✨
  • February 25, 2026
