Mystery Flow - Need help | Community
  • December 8, 2023
  • 145 views
Hello all, we’ve had a fairly major technical issue for a while now and are unable find a POC to solve this with - hoping someone can help or point me in the right direction! Our flows are already established and set up. Problem is - when someone writes in our chat, a specific message gets sent as a reply pretty much 80% of the time (not all) and the message is not is not a part of any flow.
Who can I contact to get help with this?
Best answer by Cam G.
Hi @Simal Yilmaz -- Cam from the Intercom Support team here!
Sounds like the issue your seeing may require some direct investigation and some 1:1 discussion so I’ve gone ahead and opened a conversation for you on this with our Customer Support team. We will touch base with you on this there 👍
If you don’t see that conversation on your end for whatever reason, or want to get in touch with us separately for any reason feel free to start a chat with us using the Messenger in your Workspace, or send us an email on team@intercom.io 😁
  • December 22, 2023
