Help Center Footer length | Community
  • July 16, 2024
  • 139 views
Is it possible to change the number of characters available in the Help Center Footer?
There seems to be a hard limit that is not allowing us to add our standard footer to the help centre
Best answer by Nathan Sudds
@Emma Spencer  not sure about the footer height, I need to look into that but there's a section in Styling for the help center where you can add a content area under layouts and sections.  This might help you accomplish your goal!
Customize help center - layouts and sections
Forum|alt.badge.img+8
  • July 16, 2024
  • July 16, 2024
Thanks @Nathan Sudds ,
What I was asking about was footer length - or the number of characters allowed in the footer. Currently it seems to be set to be very short. In Australia we always want to include an Acknowledgement of Country and we aren’t able to fit it in because the number of characters allowed in the footer is far too short
