Is there a way to teach the chat box to share articles without activating the Help Centre ? | Community
  • November 18, 2022
  • 8 replies
  • 132 views
We do not want our article to be searchable on line by anyone. We only want to share them in the messenger.
Best answer by Martina
Hey there, thanks look like I solved this issue. Sharing here for others may be interested in the topic:
  • yes, you can publish the help center and turn off the button "Allow your help center to appear in search results" so that the articles will not be indexed
  • you need to publish at least 10 articled before the chat box start suggesting them
  • articles need to be organized into collections
Now, I only need to understand how to make sure the operator will start to do that :)
Thanks for your help
Kevin Bendixen
In the articles settings, you can prevent your help center from showing up in online search results. Would that already solve your issue?
  • November 18, 2022
Hey Kevin, thanks so much for your reply! Yes, I saw this option. However, when I try to activate the Help Center I have always a message saying that the articles are going to appear online with a URL domain
  • November 18, 2022
Keep your help center private
  • November 18, 2022
But then when I click on the green bottom Turn on Help Center I see this messageTurn on your help center
  • November 18, 2022
J'ai fait ce que tu as conseillé Kevin. je pense que tu as raison. Normalement le help center ne devrait pas s'indexer
Dianah Tripac
  • Leading the Community @ Fin
  • November 21, 2022
Hi @kevin b​, just wondering if you could help Lana Lucia further on that. 🙌 It looks like her issue is not solved yet.
Kevin Bendixen
Not entirely sure what's missing here. The articles will be accessible by everyone once you set it live, but in reality, there shouldn't be that many people that will do it.
  • November 23, 2022
