React-Native problem building android - intercom-react-native:generateDebugRFile failed | Community
  • May 15, 2023 6:36 PM UTC
  • 7 replies
  • 2338 views
Been getting this error since upgrading react-native, an ideas?
* What went wrong:
Execution failed for task ':intercom-react-native:generateDebugRFile'.
> A failure occurred while executing com.android.build.gradle.internal.res.GenerateLibraryRFileTask$GenerateLibRFileRunnable
   > /Users/manfredxu/Documents/project/node_modules/@intercom/intercom-react-native/android/build/intermediates/local_only_symbol_list/debug/R-def.txt
Above I also see this:
> Task :intercom-react-native:generateDebugRFile FAILED
Execution optimizations have been disabled for task ':intercom-react-native:generateDebugRFile' to ensure correctness due to the following reasons:
  - Gradle detected a problem with the following location: '/Users/manfredxu/Documents/project/node_modules/@intercom/intercom-react-native/android/build/intermediates/local_only_symbol_list/debug/R-def.txt'. Reason: Task ':intercom-react-native:generateDebugRFile' uses this output of task ':intercom_intercom-react-native:parseDebugLocalResources' without declaring an explicit or implicit dependency. This can lead to incorrect results being produced, depending on what order the tasks are executed. Please refer to https://docs.gradle.org/7.5.1/userguide/validation_problems.html#implicit_dependency for more details about this problem.
  - Gradle detected a problem with the following location: '/Users/manfredxu/Documents/project/node_modules/@intercom/intercom-react-native/android/build/intermediates/packaged_manifests/debug'. Reason: Task ':intercom-react-native:generateDebugRFile' uses this output of task ':intercom_intercom-react-native:processDebugManifest' without declaring an explicit or implicit dependency. This can lead to incorrect results being produced, depending on what order the tasks are executed. Please refer to https://docs.gradle.org/7.5.1/userguide/validation_problems.html#implicit_dependency for more details about this problem.
Using
“react-native”: 0.71.7
“@intercom/intercom-react-native”: 5.0.0
Best answer by Paul M11
Hey there @manfredxu99 👋
Paul here from Intercom Support!
Thank you for your patience here 🙏 . Will raise this with our support team to take a closer look at ✅
  • May 19, 2023 4:42 PM UTC
The same issue
  • May 31, 2023 4:59 PM UTC
I’m experiencing the same issue. Do we have a solution yet?
  • Jun 29, 2023 10:30 AM UTC
I have same issue, so have any solutions?
“react-native”: 0.70.4
“@intercom/intercom-react-native”: 5.1.1
android/build.gradle
buildToolsVersion = "31.0.0"
minSdkVersion = 21
compileSdkVersion = 33
targetSdkVersion = 31
Currently experiencing the same issue on:
"react-native": "0.70.5",
"@intercom/intercom-react-native": "5.1.1",
Hi Paul, any resolution to this issue I see it has been marked as solved, but I’m currently experiencing the same issue on:
  • Jul 3, 2023 3:36 AM UTC
minSdkVersion = 21
Do not manually linking, it work well
