Product configuration Issue | Community
  • September 19, 2024
  • 174 views
Hi, while trying to configure product tour on our test website I am getting this error.
I am not sure what is causing this. I am hopping to get some help. This is a NextJs application.
Hi @Francis Lagueu ! Ebenezer here from Engineering Support👋.
Just to clarify, do you have the Messenger installed on the page you’re looking to build the Product tour on?
Also do you know if the Messenger has been installed inside of an additional iframe?
  • September 25, 2024
I am following this documentation https://developers.intercom.com/installing-intercom/web/installation#intercomboot-intercomsettings using npm install messenger sdk and configured Intercom in components where I need it available but I am still not able to configure the product tour due to the error mentioned above.
@Francis Lagueu It’s Mat from the Support Engineering Team 😀
I’ve seen similar issues sometimes it helps just to clear the browser data (I know right) but it works in most cases.
Worth trying.
