Some features not working on website (Beacons and Posts) | Community
  • June 16, 2025
  • 258 views
Hi, I have intercom set up on our website through GTM. The messenger is in the bottom and you can interact with it. I have banners working. But… when I go to set up a Beacon (tool tip) or a Post it won’t show up on the page.
Any ideas?
thanks
Best answer by Nur Nahid
Hey ​@Matt Fraser, Sounds like the Messenger itself is working fine, so that’s a good sign.
For Beacons or Posts not showing, a few things to check:
  • Make sure the targeting rules (like URL, audience filters, or event triggers) are set correctly.
  • If you're using GTM, double-check that Intercom is loading early enough on the page—sometimes timing can affect visibility.
  • Also, make sure there’s no CSS or other scripts hiding the Beacon/Post element.
If everything looks right, try loading the page in incognito mode to rule out cache or extension conflicts.
Hope that helps!
Angel Horowitz
Hi ​@Matt Fraser ! Do you have specific triggers/audience filters you’re using for the posts / tooltips? Also, for the tooltips are you using custom CSS tags, or using the options to click to target an object or by text?
  • June 16, 2025
I tried both object and text and neither showed up. They look great in the preview but not the live website. The only filter I have is for Visitors and on a specific page.
Thanks Angel.
Nur Nahid
Forum|alt.badge.img+6
  • Expert User ✨
  • June 17, 2025
Hope that helps!
