Fin sometimes switches between masculine and feminine in Hebrew despite two Guidance rules | Community
  • Jan 25, 2026 3:39 PM UTC
  • 355 views
Hi everyone,
Our bot communicates in Hebrew. Because Hebrew is gendered, we’re seeing an inconsistency: Fin sometimes replies in masculine form and sometimes in feminine form.
Both of the following Guidance rules are under Communication style:
  1. Bot self-reference is always masculine
When responding in Hebrew, always refer to yourself in masculine grammatical form. This applies to self-descriptions, actions, and statements about your role or capabilities. Do not change your self-referential gender under any circumstances.
What NOT to do:
  • Do not adapt self-reference based on the user’s gender or language.
  • Do not use feminine or neutral forms when referring to yourself.
AND:
  1. Hebrew gendered language (pronoun-aware)
When responding in Hebrew, adapt grammatical gender when addressing the user:
  • If a <Pronoun> attribute exists, use it.
  • If no <Pronoun> attribute exists, follow the gender implied by the user's Hebrew language.
  • If gender is unclear, use neutral phrasing or default to masculine. Do not ask the user about their gender.
  • Remain consistent throughout the conversation.
What NOT to do:
  • Do not guess gender from names, emojis, or profile images.
  • Do not mix masculine and feminine forms when addressing the user.
Problem:
Despite these two rules, Fin sometimes mixes masculine and feminine in the same reply, or seems to apply the “address the user” gender rule to self-references.
Question:
What’s the recommended way to structure these two Communication style rules so they don’t conflict, and so Fin consistently:
  • Uses masculine when referring to itself
  • Uses the correct gender when addressing the user (based on <Pronoun> attribute or the user’s Hebrew)
Are there known precedence/ordering rules within Communication style Guidance that could cause this behavior, or a recommended wording pattern to prevent gender mixing?
Best answer by Nico Magbiray
Hi Ben,
Hebrew's gendered grammar can definitely trip Fin up when the rules for self-reference and addressing the user are too similar. To fix this, treat Fin like a new trainee and use the Optimize button to see if your instructions are overlapping or confusing the AI. I suggest simplifying your guidance into one clear rule using bold formatting to distinguish between SELF and USER (e.g., "Always refer to YOURSELF in masculine form, but address the USER based on their <Pronoun> attribute"). After updating, run the Analyze, Train, Test, and Deploy cycle by checking your conversation logs and using the Preview tool to ensure the mixing stops. If Fin still fails, check the Event Log to see which specific rule it is trying to follow.
Nico Magbiray
Innovator ✨
  • Innovator ✨
  • Feb 4, 2026 7:28 AM UTC
Hi Ben,
Will definitely check this right away and see how it works! Thanks, ​@Nico Magbiray
