Glossary and workflow auto-translate issue | Community
  • August 21, 2025
  • 723 views
Hi everyone!
I’ve uploaded a glossary with 3 languages (default Traditional Chinese, plus English and Simplified Chinese).
However, when I run workflow auto-translate, it only applies correctly to one term (in one workflow button).
Here’s what I’ve tried so far:
  • Re-uploaded the glossary
  • Turned off all workflow auto-translate and turned it back on
But the workflows still don’t translate according to the glossary.
Has anyone experienced the same issue? Or any advice on how to get the workflow auto-translate to fully follow the glossary?
Best answer by Joseph S.
Hi Celine,
Will paste the answer here as well
Looks to me like it's done correctly. The most common blocker at this point could be the text in your workflow doesn’t match the Traditional Chinese entry exactlykeep in mind that Intercom only swaps if there’s a perfect match (spacing, punctuation, hidden characters all matter).
Here’s the fastest way to test and isolate whether it’s a bug or just a matching problem:
  1. Create a minimal test glossary CSV
zh-CN,zh-TW,en测试,測試,test
  1. 1(save in UTF-8, no BOM).
  2. Make a new workflow with the single word “測試” as the button or message text.
  3. Turn on auto-translate: see if it comes out as “test” in English and “测试” in Simplified.
  • If it works: your main glossary is fine, but your workflow text must not be matching exactly. Clean up spacing, puxnctuation, or re-enter terms manually.
  • If it fails: then it’s not a setup issue, it’s an Intercom caching/bug issue and you’ll need to escalate with support, attaching the test CSV + workflow as proof.
Let me know how it goes, and hope it helps!
Joseph S.
Forum|alt.badge.img+6
  • Expert User ✨
  • August 21, 2025
Hey,
Yeah, I’ve run into this before. A couple of things to check:
Glossary coverage: Auto-translate only swaps terms if they appear exactly as written in your glossary. Even small differences (capitalization, spacing, plural forms) can make it skip.
Workflow cache: Sometimes workflows don’t refresh translations after you re-upload. Try forcing a re-publish of the workflow after updating the glossary.
Language fallback: If your workflow text is in Traditional Chinese, but your glossary term is set under English or Simplified, it won’t apply. Make sure each language variant in the glossary lines up with the default text.
In my case, re-publishing after cleaning up glossary entries fixed it. Worth trying a minimal test: 1 workflow + 1 glossary entry, if it works, then add it in the whole workflow that you have got! Hope it helps:)
  • August 22, 2025
Hi Joseph, thanks for your suggestions!
I tried re-publish my workflow many times but still doesn’t work :(
For the language fallback that you mentioned, the screenshot shows my setting, I think each language variant in the glossary should line up with the default text?
Joseph S.
  • Expert User ✨
  • August 27, 2025
Hi Celine,
