Darshan Hiranandani : How do I extract data from my workspace and upload it to another system? | Community
  • Aug 1, 2024 7:41 AM UTC
  • 191 views
Hi Team,
I’m working on a task that involves extracting data from my workspace and uploading it to another system. I’d greatly appreciate any detailed suggestions or best practices you might have for this process.
Best regards,
Darshan Hiranandani
Hey Darshan 👋 Jacques here from Support Engineering!
You can use the Intercom REST API to access data from your workspace.
The exact process would depend on what data you’re looking to extract, but the API is definitely your best bet for accessing your Workspace data!
Jacques Reynolds
