Integration between Split.io and Intercom | Community
  • Jan 10, 2024 8:56 AM UTC
  • 193 views
Has anyone successfully integrated Split.io with Intercom?
One use case would be to drive segmentation via split as it’s how we soft launch new features. If Intercom doesn’t find the UI component to point at, it tends to just point at anything.
Hi Abu, It’s Mat from the Customer Support Team.
We are not currently planning to use Split.io, although it looks very promising.
