Rule slot competition issue | Community
  • May 31, 2026 9:28 AM UTC
  • 320 views
Hi Intercom community đź‘‹
We're mid-deployment of Fin and have run into two issues I'd love input on - both from the community and from Intercom's side.
1.
Rule slot competition - scaling concern
We've noticed that rules are not being consistently retrieved during conversations, even when written with "ALWAYS" phrasing. This is a real problem for us.
Some context:
- The Fin Academy stated Fin can use up to 100 rules in a single reply
- In practice, we're seeing what appears to be a 10–15 rule competition limit per reply
- We're only in phase 1 of our deployment - we have 3 additional product areas to support, each requiring their own specific rules
- Our sales contact from intercom indicated that the rules limit could be increased if needed
My questions:
1. What is the actual enforced limit on rule retrieval per reply?
2. If the per-reply competition slot is the real ceiling, does raising the total rules cap actually make a difference?
3. Is there a recommended architecture for scaling Guidance rules across a large, multi-product support setup - without rules getting dropped?
2.
Suppressing the automatic opener when a Procedure is triggered
When a Procedure kicks in, Fin fires an automatic opener message before the Procedure actually begins: “I can help with that”. We need to suppress this - the automatic opener text doesn't match our intended conversation style, and we can't control it when a Procedure is triggered
Is there currently a way to disable or override the automatic opener on a per-Procedure basis?
If this isn't possible today, I'd like to formally raise this as a feature request. The ability to suppress or customize the opener at the Procedure level feels essential for a smooth, intentional conversation flow.
Would love to hear from anyone who has navigated similar things, and from Intercom directly on both points.
Thanks 🙏
Best answer by Aleksei O
Hi ​@Alex Tasha 👋 For starters, you can segment the audience for Guidance using audience filters in case you have multiple products. This way, you can filter out quite a few rules targeting specific product users.
Could you share examples of your Guidance and give examples of the rules that didn’t trigger but were supposed to trigger?
Aleksei O
Super User ✨
  • Super User
  • Jun 11, 2026 7:32 AM UTC
