Does anyone use Macros for internal-facing help? | Community
  • Mar 25, 2022 3:29 AM UTC
  • 78 views
Does anyone use Macros for internal-facing agent procedural help? Step-by-step instructions? I don't want to use Guru. I want to keep my internal-facing needed knowledge available and searchable WITHIN Intercom.
Best answer by Eric Fitz
Hey @jason l11​, the primary use-case of Macros is to allow you to improve sending replies (and subsequent follow-up actions) to customers. How do you envisage using them for internal-facing help?
  • Mar 28, 2022 4:42 PM UTC
