failed to build android project | Community
  • Sep 15, 2023 5:34 PM UTC
  • 533 views
so after adding the library I get this error while building project, how to fix that?
i don’t have exoplayer on my project, i even tried to add that, but nothing really changed
FAILURE: Build completed with 8 failures.
1: Task failed with an exception.
* What went wrong:
Execution failed for task ':app:mapProductionDebugSourceSetPaths'.
> Could not resolve all files for configuration ':app:productionDebugRuntimeClasspath'.
   > Failed to transform exoplayer-2.19.0.aar (com.google.android.exoplayer:exoplayer:2.19.0) to match attributes {artifactType=android-res, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
      > Could not find exoplayer-2.19.0.aar (com.google.android.exoplayer:exoplayer:2.19.0).
        Searched in the following locations:
            https://dl.google.com/dl/android/maven2/com/google/android/exoplayer/exoplayer/2.19.0/exoplayer-2.19.0.aar
   > Failed to transform exoplayer-rtsp-2.19.0.aar (com.google.android.exoplayer:exoplayer-rtsp:2.19.0) to match attributes {artifactType=android-res, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
      > Could not find exoplayer-rtsp-2.19.0.aar (com.google.android.exoplayer:exoplayer-rtsp:2.19.0).
            https://dl.google.com/dl/android/maven2/com/google/android/exoplayer/exoplayer-rtsp/2.19.0/exoplayer-rtsp-2.19.0.aar
   > Failed to transform exoplayer-database-2.19.0.aar (com.google.android.exoplayer:exoplayer-database:2.19.0) to match attributes {artifactType=android-res, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
      > Could not find exoplayer-database-2.19.0.aar (com.google.android.exoplayer:exoplayer-database:2.19.0).
            https://dl.google.com/dl/android/maven2/com/google/android/exoplayer/exoplayer-database/2.19.0/exoplayer-database-2.19.0.aar
   > Failed to transform exoplayer-extractor-2.19.0.aar (com.google.android.exoplayer:exoplayer-extractor:2.19.0) to match attributes {artifactType=android-res, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
      > Could not find exoplayer-extractor-2.19.0.aar (com.google.android.exoplayer:exoplayer-extractor:2.19.0).
            https://dl.google.com/dl/android/maven2/com/google/android/exoplayer/exoplayer-extractor/2.19.0/exoplayer-extractor-2.19.0.aar
   > Failed to transform sqlite-2.3.0.aar (androidx.sqlite:sqlite:2.3.0) to match attributes {artifactType=android-res, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
      > Could not find sqlite-2.3.0.aar (androidx.sqlite:sqlite:2.3.0).
            https://dl.google.com/dl/android/maven2/androidx/sqlite/sqlite/2.3.0/sqlite-2.3.0.aar
* Try:
> Run with --stacktrace option to get the stack trace.
> Run with --info or --debug option to get more log output.
> Run with --scan to get full insights.
> Get more help at https://help.gradle.org.
2: Task failed with an exception.
* What went wrong:
Execution failed for task ':app:mergeProductionDebugResources'.
* Try:
3: Task failed with an exception.
* What went wrong:
Execution failed for task ':app:checkProductionDebugAarMetadata'.
   > Failed to transform exoplayer-2.19.0.aar (com.google.android.exoplayer:exoplayer:2.19.0) to match attributes {artifactType=android-aar-metadata, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-rtsp-2.19.0.aar (com.google.android.exoplayer:exoplayer-rtsp:2.19.0) to match attributes {artifactType=android-aar-metadata, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-database-2.19.0.aar (com.google.android.exoplayer:exoplayer-database:2.19.0) to match attributes {artifactType=android-aar-metadata, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-extractor-2.19.0.aar (com.google.android.exoplayer:exoplayer-extractor:2.19.0) to match attributes {artifactType=android-aar-metadata, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform sqlite-2.3.0.aar (androidx.sqlite:sqlite:2.3.0) to match attributes {artifactType=android-aar-metadata, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
* Try:
4: Task failed with an exception.
* What went wrong:
Execution failed for task ':app:processProductionDebugMainManifest'.
   > Failed to transform exoplayer-2.19.0.aar (com.google.android.exoplayer:exoplayer:2.19.0) to match attributes {artifactType=android-manifest, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-rtsp-2.19.0.aar (com.google.android.exoplayer:exoplayer-rtsp:2.19.0) to match attributes {artifactType=android-manifest, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-database-2.19.0.aar (com.google.android.exoplayer:exoplayer-database:2.19.0) to match attributes {artifactType=android-manifest, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-extractor-2.19.0.aar (com.google.android.exoplayer:exoplayer-extractor:2.19.0) to match attributes {artifactType=android-manifest, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform sqlite-2.3.0.aar (androidx.sqlite:sqlite:2.3.0) to match attributes {artifactType=android-manifest, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
* Try:
5: Task failed with an exception.
* What went wrong:
Execution failed for task ':app:mergeProductionDebugAssets'.
   > Failed to transform exoplayer-2.19.0.aar (com.google.android.exoplayer:exoplayer:2.19.0) to match attributes {artifactType=android-assets, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-rtsp-2.19.0.aar (com.google.android.exoplayer:exoplayer-rtsp:2.19.0) to match attributes {artifactType=android-assets, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-database-2.19.0.aar (com.google.android.exoplayer:exoplayer-database:2.19.0) to match attributes {artifactType=android-assets, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-extractor-2.19.0.aar (com.google.android.exoplayer:exoplayer-extractor:2.19.0) to match attributes {artifactType=android-assets, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform sqlite-2.3.0.aar (androidx.sqlite:sqlite:2.3.0) to match attributes {artifactType=android-assets, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
* Try:
6: Task failed with an exception.
* What went wrong:
Execution failed for task ':app:checkProductionDebugDuplicateClasses'.
   > Failed to transform exoplayer-2.19.0.aar (com.google.android.exoplayer:exoplayer:2.19.0) to match attributes {artifactType=enumerated-runtime-classes, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-rtsp-2.19.0.aar (com.google.android.exoplayer:exoplayer-rtsp:2.19.0) to match attributes {artifactType=enumerated-runtime-classes, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-database-2.19.0.aar (com.google.android.exoplayer:exoplayer-database:2.19.0) to match attributes {artifactType=enumerated-runtime-classes, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-extractor-2.19.0.aar (com.google.android.exoplayer:exoplayer-extractor:2.19.0) to match attributes {artifactType=enumerated-runtime-classes, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform sqlite-2.3.0.aar (androidx.sqlite:sqlite:2.3.0) to match attributes {artifactType=enumerated-runtime-classes, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
* Try:
7: Task failed with an exception.
* What went wrong:
Execution failed for task ':app:mergeProductionDebugNativeLibs'.
   > Failed to transform exoplayer-2.19.0.aar (com.google.android.exoplayer:exoplayer:2.19.0) to match attributes {artifactType=android-jni, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-rtsp-2.19.0.aar (com.google.android.exoplayer:exoplayer-rtsp:2.19.0) to match attributes {artifactType=android-jni, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-database-2.19.0.aar (com.google.android.exoplayer:exoplayer-database:2.19.0) to match attributes {artifactType=android-jni, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-extractor-2.19.0.aar (com.google.android.exoplayer:exoplayer-extractor:2.19.0) to match attributes {artifactType=android-jni, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform sqlite-2.3.0.aar (androidx.sqlite:sqlite:2.3.0) to match attributes {artifactType=android-jni, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
* Try:
8: Task failed with an exception.
* What went wrong:
Execution failed for task ':calling:ui-calling:transformDebugClassesWithAsm'.
> Could not resolve all artifacts for configuration ':calling:ui-calling:debugRuntimeClasspath'.
   > Failed to transform exoplayer-2.19.0.aar (com.google.android.exoplayer:exoplayer:2.19.0) to match attributes {artifactType=android-classes-jar, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-rtsp-2.19.0.aar (com.google.android.exoplayer:exoplayer-rtsp:2.19.0) to match attributes {artifactType=android-classes-jar, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-database-2.19.0.aar (com.google.android.exoplayer:exoplayer-database:2.19.0) to match attributes {artifactType=android-classes-jar, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform exoplayer-extractor-2.19.0.aar (com.google.android.exoplayer:exoplayer-extractor:2.19.0) to match attributes {artifactType=android-classes-jar, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
   > Failed to transform sqlite-2.3.0.aar (androidx.sqlite:sqlite:2.3.0) to match attributes {artifactType=android-classes-jar, org.gradle.category=library, org.gradle.dependency.bundling=external, org.gradle.libraryelements=aar, org.gradle.status=release, org.gradle.usage=java-runtime}.
* Try:
BUILD FAILED in 5m 8s
Best answer by Eden
Hey @rq_mehdi 👋 Eden from the support engineer team here.
Taking a look at the crash logs you’ve included, it doesn’t looks like Intercom is referenced at all. This indicates that the crash occurring when building your app isn’t an issue occurring with the Intercom SDK! If you believe there is an issue specifically occurring with the Intercom Android SDK, feel free to let us know and we can escalate this to the support team. 👍
Eden
  • Sep 20, 2023 7:08 PM UTC
