Issue with JIRA for Cloud | Community
  • May 15, 2025 5:01 AM UTC
  • 505 views
I am trying to integrate JIRA for Cloud with my Intercom Inbox. However, once a JIRA ticket is created, it is not getting linked to the Inbox panel. I manually added the link as well and it says in the note that the linking was successful - still do not see anything here.
Am I missing anything?
Best answer by Paul Byrne
Hey ​@Subham Choudhury Paul here.
If the Jira issue isn’t showing in the Inbox panel after linking, here are a few things to check:
  • Linking Method: The issue must be linked directly from the Inbox using the "Create" or "Link an existing issue" buttons. Manual links (e.g. via note) won’t show unless they include the correct metadata.
  • Conversation Context: Only issues linked to that specific conversation will appear in the panel.
  • Permissions: Make sure your Jira account has access to view the issue, and that project permissions aren't hiding it.
Try unlinking and re-linking from the panel if it still doesn’t appear, share the Jira issue key and I’ll take a closer look!
Paul Byrne
  • May 17, 2025 11:31 AM UTC
  • May 19, 2026 6:36 PM UTC
I have same issue. It is completely not clear what happening.
Hi ​@Denis Gukov, Seán here from the Fin technical support team 👋
I’m going to create a conversation with our support team so they can take a closer look and investigate further with you. They’ll be able to dig into your setup and provide more targeted guidance. Keep an eye out for a follow-up from the team shortly.
