Feature Request: Pin Chats for Better Inbox Organization | Community
Related products:Core Inbox
  • Nov 20, 2026 8:52 PM UTC
  • 4 views
I'd like to suggest a feature that allows agents to temporarily pin specific conversations to the top of their inbox without affecting the existing sorting order.
When handling a high volume of tickets, there are often conversations that require extra attention or follow-up. Being able to pin these chats would make it much easier to keep track of them while continuing to work through the rest of the inbox.
Currently, we sometimes add an internal note just to bring a conversation back to the top of the list. However, this isn't very effective, as the chat eventually gets pushed down again when other conversations are updated. It also requires adding unnecessary notes just for organizational purposes.
Sorting by priority wouldn't really solve this either, since the goal isn't to permanently prioritize certain conversations or change how the entire inbox is sorted. We just need a way to temporarily keep a few selected chats visible while working on them.
Ideally, pinned conversations would stay in a separate section at the top of the inbox, while all other conversations would continue following the selected sorting order and updating normally as new messages arrive.
This would be especially helpful during busy shifts, making it easier to manage follow-ups, avoid overlooking important conversations, and stay organized without disrupting the existing workflow.
