Implementation of a Persistent Top-Level Status Banner for AUX/Active States. | Community
Currently, when agents transition from a break or "Away" status back to "Active," there is a risk of technical lag or accidental misclicks where the status does not update correctly. Because there is no prominent visual indicator, an agent may believe they are ready to receive calls/chats when they are actually still in a non-productive AUX state. This leads to:
  • Lost Productivity: Agents sitting idle while thinking they are in queue.
  • Breached Response Times: Increased wait times for customers due to "ghost" inactivity.
  • Reporting Inaccuracies: Inflated "Break" or "Meeting" times in the agent's daily performance metrics.
    Proposed solution:
    I propose adding a high-visibility Status Banner at the very top of the agent interface that dynamically reflects the current system state.
  • Visual Cue: When an agent changes their status to "Active," a bright green banner should appear at the top of the screen.
  • Failure Warning: If the transition fails or remains in an AUX state (e.g., Break, Lunch, Training), a high-contrast banner (Yellow or Red) remains visible.
  • Accessibility: This ensures that regardless of which tab or customer profile the agent is viewing, their current "In-Queue" status is always visible at a glance.
    Impact on Productivity & KPIs
  • Efficiency: Eliminates "idle time" caused by status sync errors.
  • Real-time Awareness: Provides agents with immediate confirmation that they are successfully receiving work.
  • Performance Tracking: Ensures that the productivity data analyzed in agent reports accurately reflects active working hours rather than accidental AUX time.
