Problem:
A guidance rule or procedure that is paused or in draft on the live version can't be changed inside a release. It doesn't show up there as something you can edit or set to active. As far as a release is concerned, it doesn't exist until someone switches it on in the live version, outside the release.
Why it matters:
Releases are how we want to ship changes to Fin: bundled, tested with evals, ramped, and reversible. A new rule or procedure is often the change itself. It's the change we most need to stage and test, and the only way to ship it right now goes around the release.
What we'd like:
Draft and paused guidance and procedures shown in a release, where they can be edited and set to active. They would then go live when the release publishes, with the same pause and revert as everything else in it.
