Accessing internal article tags & better ways to convert internal → public articles | Community
  • Dec 10, 2025 5:34 PM UTC
  • 573 views
I'm syncing documentation from Notion to Intercom and I’m looking for a better way to handle internal and public articles.
Current workflow:
  1. All documentation is written in Notion.
  2. I use Intercom’s native Notion sync, but it only creates internal articles.
  3. I then use Make.com to read those internal articles via Intercom APIs and create/update public articles with the same title and body.
  4. I'd like to also copy the tags from the internal articles, but I can't find a way to access them through the API.
My questions:
  • Is it possible to retrieve the tags assigned to internal articles via the API or any other method?
  • Is there a better or more official way to convert internal articles into public ones while preserving metadata like tags?
Any guidance or recommended approaches would be appreciated!
Best answer by Paul Byrne
Het ​@Andre Romao Paul here from support engineering to help you out 🤝
The /api/v3/internal_articles endpoint currently does not expose tags in its API response. While internal articles have tag support in the underlying data model, the V3 REST API presenter only returns these fields:
  • id
  • title
  • body
  • owner_id
  • author_id
  • locale
  • created_at
  • updated_at
The V3 Internal Articles API (which OAuth apps use) intentionally limits the fields returned compared to what's available internally. Tags are stored but not exposed through the public OAuth API endpoint.
Alternative approaches:
  1. Feature Request: This appears to be an intentional API design limitation. The standard /api/v3/articles endpoint (for public Help Center articles) DOES include tags..
  1. Use Intercom's native sync differently: Instead of creating internal articles first, consider:
  • Syncing Notion → Public articles directly
  • Using article visibility/audience targeting rules to control who sees them
  • This would give you access to tags through the /api/v3/articles endpoint
  1. Workaround limitation: Unfortunately, there's no official way to retrieve internal article tags through the OAuth API. The Ember API (used by Intercom's internal UI) does include tags, but it's not accessible to OAuth apps.
I will forward a feature request for you.
Paul Byrne
  • Dec 11, 2025 2:12 PM UTC
  • id
  • title
  • body
  • owner_id
  • author_id
  • locale
  • created_at
  • updated_at
  • Dec 15, 2025 12:47 PM UTC
Thanks a lot for the detailed explanation, really appreciate it 👍
There are still some limitations:
  • I can´t currently use the native API v3, so it’s not possible to access internal article tags
  • The native Notion → Intercom sync can’t be used to directly create public articles, only internal ones.
  • Because of these limitations, there’s no supported way to convert internal articles into public ones while preserving tags.
For now, I’ll continue using Make.com to create/update public articles based on the internal articles, even though the tags won’t be included.
Thanks as well for forwarding the feature request — that would definitely help improve this workflow in the future.
