Can I embed documents in a Help Center article? | Community
  • Sep 22, 2021 3:09 AM UTC
  • 607 views
Hello, is the ability to embed documents to articles possible? Is there a workaround, or is it possible to request it as a feature request?
Best answer by Kevin Bendixen
It's not possible currently. Of course you can request this feature. There's the @Product Wishlist​ for those things. A workaround would be to upload the document somewhere else and link to it in your article. You can also use a button or export the document as a preview image and use that image as a link.
Kevin Bendixen
