Can you add anchor tags to Help Center articles that are longer? | Community
  • Sep 6, 2020 3:43 AM UTC
  • 9 replies
  • 179 views
Best answer by Eric Fitz
Hey @autumn​ - you can use the hash key ( # ) to add anchor tags to Help Center articles URLs.
For example: https://www.intercom.com/help/en/articles/167-install-intercom-on-your-website-and-chat-with-logged-out-visitors#install-the-javascript-code./p>
Sub-headers within your Article body can be used as anchors in this way.
  • Sep 8, 2020 11:45 AM UTC
  • Sep 8, 2020 3:12 PM UTC
So I'm looking to create a table of contents for an article. For example the structure will be similar to this:
What you'll learn:
  • Thing 1
  • Thing 2
  • Thing 3
Each of the bulleted "things" should pop down to that section in the article. Each section will have a sub-header title. So, how would I link the bulleted text to go to that section in the article? Would it be #Thing-1 or #Thing1?
  • Sep 9, 2020 9:51 AM UTC
In that case, it'd be # Thing-1.
Use hyphens in your anchor link to denote spaces between words!
  • Sep 21, 2020 4:46 PM UTC
Just figured this out, thanks!
  • Sep 22, 2020 10:07 AM UTC
Glad to hear it! Just for my own information, was the solution I provided the correct one? Or did you need to do anything different?
  • Sep 22, 2020 11:35 PM UTC
Yep, you were correct. Your solution worked like a charm.
  • Sep 24, 2020 9:40 AM UTC
Delighted to hear it! 🙌 That's a good one to share in @Tips, Tricks, and Workarounds​ - even if you had an example article to share with other Connectors?
  • Jan 15, 2021 10:42 AM UTC
Hey @autumn​, some great news - we've shipped this as an official feature of Articles! You can read more about it here.
  • Jan 15, 2021 3:49 PM UTC
This is so great! Thanks for sharing, @eric f11​. This will be very helpful for longer articles we have.
