How do I connect Route53 cname to help center and articles using custom domains? | Community
  • Jul 22, 2021 7:46 AM UTC
  • 240 views
Best answer by Anonymous
Hey there,
To use Route53 you'll need to setup a CNAME that points to intercom.help, and add the domain in question as a custom domain in Intercom:
https://developers.intercom.com/installing-intercom/docs/set-up-your-custom-domain#section-enter-your-custom-domain-in-intercom-articles/p>
Check out https://devcenter.heroku.com/articles/route-53#cname-recordsas a guide to setting up CNAMEs using the AWS Console.
Let me know if it works out for you 😀
  • Jul 23, 2021 10:45 AM UTC
Hey there,
