How to use subfolder for Articles/Knowledgebase | Community
  • Dec 31, 2023 6:51 PM UTC
  • 584 views
Can I get very specif instructions on how to use a subfolder, say mycompany/com/help  ( not a sub domain)
my register is Namecheap
Thank you.
Hey @Nicky Kalliongis 👋
The first step would be to set up a Custom Domain for the Help Center, see our developer docs here on how to do this 👈
If you want to configure a subpath for the Help Center, you can see our docs on how to do this in AWS Cloudfront here 👈
We don't have documentation on how to create subpaths with any other providers (such as Cloudflare), so we would recommend that you reach out directly to their support if you are having an issue creating a subpath.
Larissa Alberti
just want to make sure i understand this corect please. in order to have the help domain be
mydomain.com/help
i need to make the folder or subdirectory. - nothing to do with Intercom at all
and then i go inside intercom and point it to that address : mydomain.com/help
do I still need to make a custom domain in intercom?
and if i am corect all the styles i still do in intercom
im basicly just pointing it from intercom to the subdirectory when i enter the address mydomain.com/help
do I have this correct, please? thanks!
  • Jan 28, 2024 5:15 PM UTC
Hey there @Nicky Kalliongis !
What you say sounds correct! Like Larissa mentioned, you can find all of the steps to set up your Custom Domain here.
You’ll set up the Custom Domain with your DNS provider and add the Custom Domain to your Intercom Help Center Settings page.
If you want your help center to be secure, you’ll need to set up SSL with a provider such as CloudFlare or CloudFront. This is mentioned in those linked docs.
