Is it possible to resize images in the knowledge base articles? | Community
  • Dec 2, 2022 11:09 PM UTC
  • 411 views
Best answer by Casey Maxwell
It looks like resizing images is now possible, but it’s not super user friendly. I was hopeful for a “drag and drop”, auto-resize which would keep a fixed ratio. Right now, this is the UI (you can manually adjust the width and height, but this doesn’t keep them locked together to scale the image properly).
I submitted a request here for the more user-friendly resize functionality:
Kevin Bendixen
It's not possible currently. My workaround is to create a PNG file with a transparent background and use that as a way to scale the images.
  • Apr 20, 2026 3:07 PM UTC
