Is there any way to preserve white space in code blocks? | Community
  • Jan 25, 2022 8:31 PM UTC
  • 67 views
I've created a bunch of code blocks in my help article with carefully formatted whitespace. When I save the article the whitespace is stripped. I'm talking specifically about whitespace to the left of content.
This:
" some-command"
Becomes:
some-command
I had to quote the first example because the help center does the same snipping...
When I edit the article the whitespace is back! How can I keep it in place for viewers of the article?
Best answer by Aparna
Hey @frans​ ! Looks like a limitation on our end. But we can open up a bug issue for you, if you could open a conversation with the support team from Messenger in your workspace.
  • Jan 27, 2022 5:18 PM UTC
