Redirects and Canonicals help, SEO Site audit | Community
  • Jan 6, 2024 4:27 PM UTC
  • 536 views
I conducted a site audit of my Help Centre and it returned a lot of redirects and 403s. The 403s I was able to fix. But the redirects and canonicals, I don’t know how to fix.
Any help is appreciated.
Best answer by aykut.aydin
Hey @Nat Ng
Thanks for the message you posted here. Our team will need additional information from you to investigate this. So I have escalated this with the Support Engineering team as a conversation. You will receive a reply from them in there as soon as possible. 👍🏻
aykut.aydin
  • Jan 11, 2024 4:26 AM UTC
Hey @Nat Ng
To fix redirects and canonicals after your SEO site audit, start by reviewing the redirect chains and loops in your Help Centre. Ensure that each redirect points to the correct final destination and avoid unnecessary multiple redirects. For canonicals, check that each page has a proper canonical tag directing search engines to the preferred version of the page. I was facing the same issue with my website apne tv and I did the same practice. My issue got resolved.
  • Sep 11, 2026 9:27 AM UTC
For cleaning up redirect chains and canonical issues, a good crawler tool helps find the problems. I also use https://crowdo.net
  • Nov 6, 2026 1:58 PM UTC
Redirects and canonical issues can be a little tricky, especially on a Help Centre with lots of existing URLs. I’d start by checking whether the redirects are intentional and whether they point to the correct final URLs. Before making major changes, checking seo company reviews can also help you find professionals experienced in technical SEO. For canonicals, make sure each important page has the correct preferred URL and avoid conflicting canonical tags. Also, check for redirect chains and loops, as these can affect crawling. I recommend fixing the most important pages first and running another site audit afterward to see what remains.
