The Help Center article discusses the ascending sort function. | Community
  • Apr 27, 2026 6:01 AM UTC
  • 272 views
I am using a translation tool to write this text.
I would like a feature that sorts the Help Center articles in ascending order, from top to bottom, by publication date.
The chatbot gave the following response:
Currently, there are no plans to implement a feature that automatically displays collections in order of publication date within the Help Center.
Currently, the only way to sort items within a collection is by manually rearranging them using drag and drop; automatic sorting (e.g., by publication date) is not possible.
Best answer by Aleksei O
Hi ​@MOTA車買取 ! 👋
If I understood you correctly, your goal is to rearrange the order of the articles visible to the customers in Help Centre: they can be rearranged manually once added to the collection. An article that is not added to the collection cannot be rearranged.
On the other hand, could you please share a bit more about how you use Help Centre?
Aleksei O
Super User ✨
  • Super User
  • Apr 27, 2026 11:27 AM UTC
Hi ​@MOTA車買取 ! 👋
