What is the best way to include screenshots and images in my articles? | Community
  • Apr 19, 2021 8:35 PM UTC
  • 836 views
Oftentimes, my images are too big. As in, when I insert a screenshot from my phone, the article displays it matching the width of the screen. The result is that the images are blown up, look too big, and are not as easy to use as I would like. Are there any good solutions out there that I am missing? Thanks!
Best answer by Kevin Bendixen
We had the same problem. I have created a custom Photoshop action to take care of this. Among other things, it differentiates between portrait and landscape mode of the screenshot and then resizes the image and increases the canvas size. That creates a transparent border around the images making them fit into the articles a lot nicer. This is the result in our help center:Bildschirmfoto 2021-04-20 um 09.48.19Bildschirmfoto 2021-04-20 um 09.47.22
Brent
Super User ✨
  • Super User ✨
  • Apr 20, 2021 1:31 AM UTC
Hiya,
I'm not aware of any way to resize in Intercom at this point but it would be a great feature request.
I'm on a mac and use a clipping tool called Skitch. When I take the screenshot I always use the crop/resize tool to take it down in size before pasting it into an article or saving it. Seems to work ok and not lose too much clarity. I'm sure there are other tools out there though but that's how I do it for now when needed. Hope that helps, if not answer it well.
Kevin Bendixen
Milan
  • Apr 20, 2021 10:55 AM UTC
You need to size images before putting them into an article.
There are not really many styling options in Article editor, it's not a WordPress or WYSIWYG kind of tool.
I assume the reason for not having this feature in Intercom is because the team wants to:
  1. keep it very simple
  2. keep it responsive (as the articles should be visible on chat widget and mobile devices) - that's why the image is always full-width unless it is really low width originally.
