Automatic carousels not showing with Android SDK | Community
  • Jan 15, 2026 1:00 PM UTC
  • 320 views
Hi there! We’ve recently recieved reports from our support team that carousels aren’t displaying within the app.
In our android code, we initialize intercom, and then if we are authenticated, we call loginIdentifiedUser after. This logic has been unchagned for a while and had worked for well over a year.
Through debugging we have found that adding an artifical delay (9 seconds) between initialize and loginIdentifiedUser results in the carousesl to show again. Without the delay, login completes successfully (the callback returns a success), but the carousels don’t show.
Is this expected behavior, or something on our end? Guidance would be greatly appreciated here
We’re using version 17.4.0 of intercom.
Hi ​@Eddy Butcher ! Ebenezer here from Engineering Support👋.
Your delay workaround points to a timing bug; we’ve seen similar reports.
I believe the upgrade to 17.4.1 should fix this issue.
