Close button not working when using presentContent on iOS SDK 19.2.x | Community
  • Oct 9, 2025 3:46 PM UTC
  • 429 views
We are having issues when using presentContent for presenting an article, the close button does not close the modal, though it can be closed with a drag down.
any workaround?
Hi ​@Melvyn Hills and ​@Luis Espinoza,
Fixes for issues with articles have been released in recent versions, you can upgrade to 9.3.2  for react-native and 19.3.2 on iOS to resolve these.
Hi ​@Luis Espinoza , Seán here from the Intercom engineering support team 👋
Most likely the “X” tap is being intercepted by another view/gesture layered above Intercom; drag-to-dismiss still works because it’s handled by the system sheet.
What to check
  • Any overlays/extra windows (banners, HUDs, toasts) or elevated UIWindow.Level that could cover the nav bar area.
  • Global UITapGestureRecognizer/UIPanGestureRecognizer on the window or root view (especially with cancelsTouchesInView = true).
  • Transparent “cover” views in the safe-area/top region.
  • That you’re calling Intercom.presentContent(...) on the main UI thread.
What to try
  • Temporarily disable overlays/gestures and re-test.
  • If you’ve disabled swizzling or use custom windows, test with a plain window to isolate.
  • Update to the latest 19.2.1 build (which you may have already tried).
Failing these let me know and I will pass this to our direct support team for further investigation!
The issue comes from Intercom, not from anything above.
It happens when opening an article directly with Intercom.presentContent(IntercomContent.articleWithArticleId("132456"))
It’s working fine when opening Messenger with any other means or type of content (collection, composer,..)
intercom-react-native 9.1.2 / iOS SDK 19.2.1
Basic functionality like this should get better QA, this is the very least expected from a major brand and expensive product as Intercom.
