Is there a way to darken the background of the product tours? Our entire product design is in dark mode, so bright white product tour posts are a bit jarring. | Community
  • Mar 16, 2021 8:27 PM UTC
  • 289 views
Best answer by Milan
Not at this moment, but in some other thread (https://forum.intercom.com/s/question/0D52G00004r2mEkSAI/whats-the-vision-for-product-tours Intercom guys said they are working on many Product Tours improvements and I hope this is one of them as I really emphasized the need for that :)
Milan
  • Mar 16, 2021 10:19 PM UTC
  • Mar 16, 2021 10:26 PM UTC
hmmm. thx. no hacks, either?
Milan
  • Mar 16, 2021 10:37 PM UTC
You can try impacting CSS - I've seen it work on other Intercom elements (messenger) but this is not a recommender thing and definitely something that might not work 100% due to cross-domain (your page is on your domain but messenger/product tours are loaded in iframe that is under Intercom domain).
Actually, I'm about to test the CSS changes that should reposition and resize the chat widget, similarly, it might work with Product Tour balloons but lest see if anyone on the Intercom side can confirm this is even possible... @eric f11​ can maybe help us here and ask around.
  • Mar 19, 2021 10:05 AM UTC
Hey @user382​, thanks for tagging me in here. There's currently no way to change the background colour of a pointer step in a Product Tour. I wouldn't recommend trying to get hacky with the CSS, either, as this will likely result in some unexpected behaviour. As you mentioned, @user892​'s best course of action here is to submit this feedback in the @Product Wishlist​ group!
