Hello All,
We’re migrating support tickets from Jira Service Management (JSM) to Intercom using a script we built in-house, with a little help from AI. The tickets are coming across with all the data we need, including their original Jira creation dates. So far, so good. Then I opened Reports.
For example, a ticket created in Jira on January 23, 2026, and imported into Intercom in November 2026 has the correct January date in its created_at field. But when I build a report in Intercom, that ticket is counted as created in November.
That makes it difficult to report on how many support tickets we actually received each month before the migration. At this rate, November is going to look very busy.
Has anyone run into this? Is there a way to make Intercom Reports use the original creation date for imported tickets? If you’ve found a workaround for reporting by the original month, I’d love to hear how you did it.
Lionel
