Ability to delete a pending draft of a published article and keep the published article | Community
A pending draft may be removed when the unpublished edits are outdated, no longer approved, or were saved by mistake, while the live article should remain unchanged.
This helps keep the published version as the clear source of truth and avoids confusion from unused draft content sitting in Knowledge/version history.
