Add link to Article in webhook event when using Article Inserter | Community
  • September 2, 2024
  • 118 views
Andrii Fedyk
Attached article to a message
When an article is added to a message, the related webhook doesn’t include any article information:
The link to article will he helpful during the integration with 3th party platforms.
The similar issue was well described here
  • September 3, 2024
Hi @Andrii Fedyk
Jennifer here from Intercom
Thanks for this feedback. I’ll keep my fingers crossed for you 🤞
  • September 3, 2024
New→Discussion ongoing
Hey ​@Jennifer K,
I saw that the idea was moved to Discussion Ongoing. Has the the intercom team already done determined the necessary time, or is this this feature possible?
Regards
Andrii Fedyk
  • May 26, 2026
The issue was first reported here:
Also, inserted articles are not available via the REST API. As a result, there is currently no workaround to get article details for external platforms.
  • May 26, 2026
This feature is needed to streamline the process. Current work around (Copy&Paste manually) is time consuming, especially in volumes.
