Article review workflow | Community
I’d love to see some features to enable an article review workflow. For example, additional status categories (pending review, in review, reviewed), reviewer markup and/or comments.
  • April 16, 2024
Hi @Colleen Weatherall
Jennifer here from Intercom 😀
I will pass this feedback on to our product team as a feature you would like implemented. I’ll keep my fingers crossed for you.🤞
  • April 16, 2024
New→Discussion ongoing
The ability to collaborate when writing articles, like being able to comment or suggest edits, is critical for us and is what is currently preventing us from using the Intercom Help Centers more.
Context: Our documentation is not always written by subject matter experts but by Support or Product team members. For more advanced documentation, we’d like subject matter experts to be able to review a help article and provide with feedback (inline comments would be great).
  • July 17, 2024
@Mikael Grave Same. We can’t have an Intercom account for each of our SMEs. The ability to make a PDF at least would help.
Forum|alt.badge.img+8
@Colleen Weatherall  Although the collaborative features aren’t fully there, when working with teams on improving their article workflow we’ve found the combination of tags and views to be very helpful!
Basically, create a few tags related to your workflow and tag the articles in draft.
Then go to Add Filter button in the top of the All Articles section and filter by tag -- select one of the tags click Save View, add an icon and name for the view i.e. Pending and then repeat for the other statuses.
Here’s an example with an approval workflow
You won’t have commenting etc but it can help with some of the challenges of that last step of finalizing articles.   We are also giving teams suggestions to use this for managing content that needs to be updated etc, tag. an article when you see it has outdated content so when someone has time to fix the article if they can’t do it on the fly -- they tag it as outdated but that workflow would definitely improve a lot if you could add comments etc.
I need to write up an article or make a video about this workflow, maybe this is a good one for the tips section @Diana Tripac 😁
OHMYGOSH This!! Having to manually work with Word documents etc to get comments and approvals on some types of documentation is incredibly tedious and well behind what other help centres offer as standard :)
