edit help center article to change language | Community
When setting up a new help center, language settings were not been properly set. After adding articles, we fixed the language settings, but articles already added are categorized to the bad language.
We started to edit the articles in hope language setting can be changed for existing articles, but the field is read-only.
It would be great to be able to change the language category of exisiting articles, or copy / move article text among language versions.
