Intercom Android SDK vulnerability not fixed | Community
Related products:Security & Compliance
There is a vulnerability not fixed even in latest Intercom Android SDK 17.4.2:
org.msgpack:msgpack-core should be 0.9.11 or greater
|    +--- io.intercom.android:intercom-sdk-base:17.4.2
|    |    +--- io.ably:ably-android:1.5.0
|    |    |    +--- io.ably:network-client-okhttp:1.5.0
|    |    |    |    +--- io.ably:network-client-core:1.5.0
|    |    |    |    \--- com.squareup.okhttp3:okhttp:4.12.0 (*)
|    |    |    +--- org.msgpack:msgpack-core:0.8.11
Could you please update io.ably:ably-android to latest 1.6.1 to see if it fixes the vulnerability?
More Info
(Maven)
< 0.9.11
0.9.11
Summary
Affected Components:
org.msgpack.core.MessageUnpacker.readPayload()
org.msgpack.core.MessageUnpacker.unpackValue()
org.msgpack.value.ExtensionValue.getData()
A denial-of-service vulnerability exists in MessagePack for Java when deserializing .msgpack files containing EXT32 objects with attacker-controlled payload lengths. While MessagePack-Java parses extension headers lazily, it later trusts the declared EXT payload length when materializing the extension data. When ExtensionValue.getData() is invoked, the library attempts to allocate a byte array of the declared length without enforcing any upper bound. A malicious .msgpack file of only a few bytes can therefore trigger unbounded heap allocation, resulting in JVM heap exhaustion, process termination, or service unavailability. This vulnerability is triggered during model loading / deserialization, making it a model format vulnerability suitable for remote exploitation.
