[Modern] Allow Customization of Homepage and Article Title Width | Community
Current Issue
In the Modern Help Center template, the display width of homepage and article titles is restricted and cannot be adjusted through the settings.
As a result, titles may wrap at unintended positions, making it difficult to achieve the desired layout.
1. Homepage Titles
  • In some cases, inserting spaces into the title can help control where the text wraps.
  • However, the results vary depending on the selected font, and the text does not always wrap as intended.
  • Certain fonts may also cause display inconsistencies depending on the browser, making this an unreliable workaround.
2. Article Titles
  • Inserting spaces into article titles does not work as a workaround, because the spaces are ignored in the rendered display.
  • Currently, the only way to change where an article title wraps is to modify the title text itself.
3. Differences Between the Settings Preview and Published Display
  • The appearance shown in the settings interface does not consistently match the actual appearance after changes are published.
  • As a result, display issues can only be identified and adjusted after publication.
  • For article titles in particular, even if an unintended line break is discovered after publication, there is no way to correct it without changing the title itself.
Operational Impact
Our workflow requires all article content, including titles, to be finalized and approved before publication.
Under this workflow, changing an already approved article title after publication solely to adjust its visual line wrapping is not a practical option.
Furthermore, because the settings preview does not accurately reflect the published appearance, it is difficult to identify and resolve line-wrapping issues in advance.
Consequently, we effectively have no reliable way to control line wrapping in article titles.
Feature Request
Please allow Help Center administrators to customize the display width of homepage and article titles in the Modern template through the settings interface.
Specifically, we would like to be able to:
  • Adjust the display width of homepage titles.
  • Adjust the display width of article titles.
  • Ensure that the title width and line wrapping shown in the settings preview accurately reflect the published appearance.
This would allow us to achieve the intended layout without modifying the actual title text.
It would also enable teams with pre-publication content approval workflows to maintain content consistency while ensuring that titles are displayed appropriately.
