October helpdesk roundup: Workforce Management, flexible snooze, follow conversations, macro analytics and more | Community
  • Oct 23, 2026 4:53 PM UTC
  • 37 views
Dianah Tripac
October helpdesk roundup: what shipped in Intercom this month
Here's a round-up of the latest Intercom Helpdesk releases from the past couple of weeks. Full details are in the Intercom changelog.
👥 Workforce and routing
  • Workforce Management is now available with the Pro add-on (15 Oct). Forecast volume, build and reuse schedules, see where you're short-staffed, and review team performance, all inside Intercom. If you used it during the beta, your setup is still there, but you'll need the Pro add-on to keep using it.
  • Skill-based routing for phone calls (16 Oct). Calls now ring teammates with the matching skill first, using the same skills you already use for chats and emails.
📥 Inbox
  • Flexible snooze options (23 Oct). Admins can create their own snooze options, such as "In 2 hours" or "Friday at 5pm", group them into lists, and choose which teams use each list.
  • Follow conversations and tickets (21 Oct). Stay in the loop on a conversation without being assigned to it, with a new "Followed by" filter in Search and Views.
  • Save any Inbox search as a View (19 Oct). One click turns your filters into a View in your sidebar, and date presets like "Last 30 days" keep rolling.
  • Dictate in the Inbox (14 Oct). Speak your replies and notes for up to two minutes, then edit before sending.
📝 Macros
  • Macro Usage Analytics (16 Oct). A new Usage tab shows how often each macro is used, by whom and in which conversations, so you can find and bulk-delete stale ones.
  • Macro Admin Mode (9 Oct). Teammates with the "Can manage shared macros" permission can view everyone's personal macros and convert good ones to shared macros.
💬 Messenger and outbound
  • Search inside a Messenger conversation (15 Oct). Find text in a long conversation, with every match highlighted.
  • Branded SMS numbers (13 Oct). Assign SMS numbers to a brand once, and Intercom sends from the matching number automatically. Replies are tagged with the brand, and Fin answers from that brand's Help Center.
See all the details: intercom.com/changes
💬 Over to you: Which of these would make the biggest difference to your team, and what's still on your wish list? Share it in the comments, or add it to the ideas section.
  • Oct 27, 2026 11:34 PM UTC
I am surprised to find that phone call volume (through Intercom’s own phone feature and system) isn’t included in the Workforce management toolset. Phone calls are a big part of support, and a big time chunk for agents as an agent can only be on one call at a time. We also do a lot of screen haring via messenger and that wouldn’t be tracked as well since that is considered a “phone” call.
Would love to see this channel added ASAP otherwise its a half baked and unusable feature.
​@Dblearon thanks for flagging the importance of this gap - we now have phone support early access available and planned to go live to all customers with Workforce Management access through the Pro add-on in the coming weeks. If you’d like early access please reach out through the messenger to ask for that to be enabled for your workspace.
