How do I embed Vimeo videos to tooltips? I have tried embedding the video as well as downloading the video and uploading it as a video clip?
Best answer by Nathan Sudds
View originalHow do I embed Vimeo videos to tooltips? I have tried embedding the video as well as downloading the video and uploading it as a video clip?
View originalHi
When editing the tooltip content you have the this + sing where you can choose to either add video (choose one from your computer) or embed it (from youtube, vimeo, etc)
Does that work for you?
Â
Â
Hi Milan. Yes, I have both options but neither worked for me.Â
I just tested with a random Vimeo video (The AI created beer commercial actually) and it worked correctly, but it’s a publicly available video -- see here:
Â
Here’s the link if you want to try embedding it to see if it works for you:Âhttps://vimeo.com/821962936
Â
Â
