Hi there. I'd like to know if there's a way to adjust my table's columns width so it looks better. I've been trying to click and drag on the lines but it doesn't work. Has anyone been able to do it? Thanks in advance | Community
  • May 26, 2022
  • 229 views
Table example
Best answer by Aparna
Hey @rgomes! At the moment it is not possible to re-size column or rows, change the colour or composition of the table borders or re-arrange columns and rows. I will suggest you flagging it in the product wishlist page.
  • May 30, 2022
  • June 15, 2022
@aparna​ +1 on this, would really help.
  • June 28, 2022
Hey @tim u​ ! I would suggest you the same. Please add it in the product wish list page here. So the product team can review it.
