How can I embed videos in an article?
I want to embed a video in an article, how do I do that?
Best answer by Eric Fitz
When writing an article, you can insert a video using the Articles toolbar! The video option is the second icon from the left.
You can embed any video hosted on YouTube, Wistia or Vimeo.image
If you want to add a GIF, just select the image icon from this toolbar, and select a .gif file.
  • 1630 replies
  • June 25, 2020
is there any option to insert videos von tiktok, or at least with an embed code?
  • January 26, 2024
I can add the video by the URL but when I add ?rel=0 to the end of the video URL, to keep related videos from popping up,  it does not disable the related videos. Can this be fixed?
  • 6 replies
  • December 16, 2024
Has anyone figured out which URL to use when inserting Microsoft Stream videos? I can’t get it to work and tried basically all possible options (URL, full embed code, part of the URL in the embed, no parameters etc.). I reached out to their customer support to no avail.
Nur Nahid
Super User ✨
  • Super User ✨
  • 95 replies
  • December 17, 2024
  • 6 replies
  • December 18, 2024
Hi Nur, which URL would you use? As mentioned before I can’t get it to work. I set the URL to public. Tried the regular URL, The embed URL and part of the URL without the parameters.
Hi ​@Rutger, you can find all you need to know about the articles here.
  • 334 replies
  • December 29, 2024
@Rutger Did you get this figured out? I wonder if you can use the Embed option in the Share dialog for Microsoft Streams and then just pull the URL that is in the embed code -- and try that as the URL in the Articles toolbar for Intercom to insert the url.
I don’t have a Microsoft Streams video to try but based on the instructions here from another platform they use the whole embed code but it seems there’s an embed url in the iframe that you may be able to extract.
  • 6 replies
  • January 3, 2025
Unfortunately not. I tried your suggestion before to no avail.
